Mentions, emojis, etc don't work properly in usercard details
Users reported that HTML elements like mentions and emojis don’t render properly inside <details> sections in user bios on Discourse, even on the latest version. twofoursixeight and bob_the_tomato demonstrated the issue visually and with code, showing that content inside <details> appears as raw HTML (e.g., <br> tags) when expanded. Richie questioned whether this was intentional design rather than a bug. zogstrip clarified that while security limits styling/markdown in user cards, allowing <details> tags themselves is unintended and qualifies as a bug. In post 9, zogstrip explained the root cause: the excerpt parser was misinterpreting <details> tags. The fix replaces the entire <details> block in excerpts with a collapsed indicator — “:play_button: summary” — mirroring default browser behavior. This change was implemented via GitHub PR #30229.
If you put a details section in your bio and open it, the HTML properties don’t work. Happens even on the latest discourse.
When using the details feature in discourse, and putting it in your bio [first 2 lines], when you click it, it shows as:
[text put in] <br>
Is this not by design, rather than a bug? :thinking:
For obvious security reasons, we support a very limited set of styling / markdown in the user card.
While this doesn’t look like a security issue, I think it’s a bug since we should not allow <details> tags.
Turns out the issue was our excerpt parser which was trying to be too clever with <details>.
I decided it doesn’t quite make sense to have those in the excerpt and instead replaced the whole content of the <details> block with “▶ summary” (“summary” being what’s written as the summary of the details block), like how they appear in the browser by default.
https://github.com/discourse/discourse/pull/30229
This topic was automatically closed after 13 hours. New replies are no longer allowed.
