חצר שיחזור/storybook?
Does discourse offer a boilerplate playground like storybook to test ui changes in one place? Currently, when I update a theme I am having to search across the platform for all use cases such as the new topic btn, create category btn, double btn, etc.
I would love to see all the btns, for example, in one place.
I came across this PR where they had the btns laid out similar to storybook, though the edge cases created by discourse were missing: Update some missing cases for button border-radius by tracey-le · Pull Request #5 · awesomerobot/discourse-button-styles · GitHub
Thanks!
Does the styleguide help you? I think that’s where those screenshots were taken
You can also create a separate theme that normal users can’t select and try out all your changes there.
yes, thank you!
Do you know if the styleguide has known bugs? It appears that the btn-flat, for example, is missing from the styleguide despite having a header. Inspect also show’s that section as missing any elements.
I noticed some broken sections too, like the category badges, which were removed in core about 1 year ago. I also had problems with the topic map.
I think in the designers webinar they also talked about styleguide and that it is only updated when there is time, and pull requests are always welcome
Darn, thanks. I created a new post about some of the bugs I’ve found. Haven’t even dared to start down the accessibility/WCAG issues :sob:
Thanks for you responsiveness and help! Really appreciate it!
