Press the , (comma) key on your keyboard, to open GitHub codespaces
Use ‘change options’ to customize the machine. Technically, the 2-core machine will work, but we recommend using at least 4-core for a better experience.
Run the default build task using Cmd/Ctrl + Shift + B.
This will install dependencies, migrate the database, and start the server. It’ll take a few minutes, especially on the lower-end machines. You’ll see “Build successful” in the terminal when it’s done.
Run the dev/admin/create task. Open the command palette with Cmd/Ctrl + Shift + P and search for “Tasks: Run Tasks”. It will present a menu of tasks; select dev/admin/create off of that list. You’ll be prompted to enter an email address and a password for your admin user.
Visit the “Ports” tab, and click the button for port 3000. This will open a new tab showing your development copy of Discourse
The VSCode environment will automatically be configured with our recommended settings and extensions, including automatic linting and formatting.
To minimize usage, make sure to run “Codespaces: Stop Current Codespace” from the command palette (Ctrl + Shift + P or Cmd + Shift + P) when you’re finished. If you forget to do this, the Codespace should be shut down automatically after your account’s configured idle time (default 30 mins). But, there are some situations where the codespace will not be detected as idle, so it’s best to stop it deliberately.
Running tests
The first time you run tests, you’ll need to install testing dependencies, including Playwright and the discourse_test DB. You can run the deps/testing task to install those. Open the command palette, select “Tasks: Run Tasks”. It will present a menu of tasks; select deps/testing off of that list.
Discourse’s sample vscode .vscode/settings.json and .vscode/tasks.json will be copied when you first boot the codespace. From that point forward, if you want to use the latest sample config, you’ll need to manually copy .vscode/settings.json.sample to .vscode/settings.json.
This document is version controlled - suggest changes on github.
I found a problem: it creates the following categories when started:
General, Staff, Staff67d17c71d8026b365c4c6657a9a9b5eb, and General(followed by random string and numbers).
Can those with the random string an numbers not be made? I could delete the General clone, but not the Staff vlone, as it has the FAQ topic (this is also in the regular Staff cat, so there’s no point).
[2024-12-12 10:31:26] [STARTED]
[2024-12-12 10:31:26] 'system' has started the backup!
[2024-12-12 10:31:26] Marking backup as running...
[2024-12-12 10:31:26] Making sure '/workspace/discourse/tmp/backups/default/2024-12-12-103126' exists...
[2024-12-12 10:31:26] Making sure '/workspace/discourse/public/backups/default' exists...
[2024-12-12 10:31:26] Updating metadata...
[2024-12-12 10:31:27] Dumping the public schema of the database...
[2024-12-12 10:31:28] pg_dump: error: connection to database "discourse_development" failed: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL: Peer authentication failed for user "postgres"
[2024-12-12 10:31:28] EXCEPTION: pg_dump failed
[2024-12-12 10:31:28] /workspace/discourse/lib/backup_restore/backuper.rb:173:in `dump_public_schema'
/workspace/discourse/lib/backup_restore/backuper.rb:36:in `run'
/workspace/discourse/lib/backup_restore.rb:13:in `backup!'
/workspace/discourse/app/jobs/regular/create_backup.rb:10:in `execute'
/workspace/discourse/app/jobs/base.rb:322:in `block (2 levels) in perform'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/workspace/discourse/app/jobs/base.rb:309:in `block in perform'
/workspace/discourse/app/jobs/base.rb:305:in `each'
/workspace/discourse/app/jobs/base.rb:305:in `perform'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:202:in `execute_job'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/workspace/discourse/lib/sidekiq/pausable.rb:132:in `call'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:182:in `invoke'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:169:in `block in process'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:113:in `local'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:263:in `stats'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:13:in `call'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:80:in `global'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:124:in `block in dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:39:in `prepare'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:123:in `dispatch'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:168:in `process'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:78:in `process_one'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:68:in `run'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:8:in `watchdog'
/home/discourse/.bundle/gems/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:17:in `block in safe_thread'
[2024-12-12 10:31:28] Cleaning stuff up...
[2024-12-12 10:31:28] Removing '.tar' leftovers...
[2024-12-12 10:31:28] Marking backup as finished...
[2024-12-12 10:31:28] Notifying 'system' of the end of the backup...
This happens whenever I boot up the forum with bin/ember-cli-u.
When clicking the Backup in the Admin panel, I get:
[2024-12-12 10:34:57] [STARTED]
[2024-12-12 10:34:57] 'NateDhaliwal' has started the backup!
[2024-12-12 10:34:57] Marking backup as running...
[2024-12-12 10:34:57] Making sure '/workspace/discourse/tmp/backups/default/2024-12-12-103457' exists...
[2024-12-12 10:34:57] Making sure '/workspace/discourse/public/backups/default' exists...
[2024-12-12 10:34:57] Updating metadata...
[2024-12-12 10:34:57] Dumping the public schema of the database...
[2024-12-12 10:34:57] pg_dump: error: connection to database "discourse_development" failed: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL: Peer authentication failed for user "postgres"
[2024-12-12 10:34:57] EXCEPTION: pg_dump failed
[2024-12-12 10:34:57] /workspace/discourse/lib/backup_restore/backuper.rb:173:in `dump_public_schema'
/workspace/discourse/script/spawn_backup_restore.rb:9:in `backup'
/workspace/discourse/script/spawn_backup_restore.rb:31:in `block in <main>'
/workspace/discourse/script/spawn_backup_restore.rb:4:in `fork'
/workspace/discourse/script/spawn_backup_restore.rb:4:in `<main>'
[2024-12-12 10:34:57] Cleaning stuff up...
[2024-12-12 10:34:57] Removing '.tar' leftovers...
[2024-12-12 10:34:57] Marking backup as finished...
[2024-12-12 10:34:57] Notifying 'NateDhaliwal' of the end of the backup...
If you’re talking about the ‘devcontainer’ branch shown in the footer of the second image, then you should ignore it. The screenshots were taken before devcontainer configuration was available on the main branch.
before you press it tho you need to make an admin account in the code can someone send me some pictures showing how to do it because I finally have a away to my own discourse but I cant do it without knowing how to set it up so can someone give images so I can see how to do it
לא בטוח אם זה קשור ל-Codespaces או לסביבת לינוקס בלבד, אבל כשאני מתחבר ויוצא תוך כדי התחזות והחלפה בין משתמשים, הפקודה bin/ember-cli -u פשוט מסתיימת, ללא לוגים שמצביעים על שגיאות כלשהן שגרמו לכך. וה-codespace מעודכן עם מאגר ה-Discourse.
