BBcode [quote] tag tronkeert toeschrijvingen na de eerste komma
When quoting someone using the BBcode [quote] tag with an attribution, and that attribution includes a comma, i.e. [quote=“foo, bar”], everything following the comma is truncated, thus:
This is, admittedly, a rather odd use case and one which I only ran into because I’m migrating old WordPress comments over to Discourse and as such had a bunch of generated attributions along the lines of “Foo <foo@bar.quux>, on 2020-10-24 11:31, wrote”.
Easy workaround: lose the commas. But I figured it was worth posting just in case anyone else runs into the same thing.
This is how the quote tag works in discourse, so after the comma it’s expecting post, topic, and username. If your put something else, it’s not expected to work.
[quote="Alistair Young, post:1, topic:336217, username:avatar"]
Sometimes it’s possible to track down the correct post to attribute, but others it’s not. If you have the id of the post it’s referring to you could do a lookup and get the info.
I knew about the Discourse-specific format, but I was also somehow under the impression that it would - as an intentional behavior - default to just displaying the tag-text for anything that didn’t parse properly in that format as a way of quoting things from outside Discourse?
I guess that I’m incorrect in that belief, and that being the case, the behavior is explained. Although it would be awfully convenient if there was a quote tag equivalent for quoting from extra-Discourse places.
You could do it with a plugin that would bake the stuff into the posts. If a client asked me to do it, I’d likely do it by moving the quote info into the raw text (like the line above) so that it would work without a plugin.
