Systeemgebruikersavatar wijzigen naar aangepast werkt niet met pictogramavatar-melding
Hello :wave:
I am stuck a little bit with changing the system user avatar. Until now I used the use_site_small_logo_as_system_avatar setting but now I want to change it with custom image. So I went to system user preferences and upload a new profile picture. It seems it changed everywhere to the new avatar except the notifications icon avatar (user menu and notifications page), where it use the letter avatar. But I see in Meta it seems works with the custom system avatar.
Screenshot 2024-11-17 at 4.02.18
On my site it uses the letter avatar after changing to custom image.
Screenshot 2024-11-17 at 4.04.07
What am I missing? Thanks :slight_smile:
We have same setup and it sounds like it should be working for you. I can’t think of anything else that could be blocking it :thinking: :face_with_monocle:
This is our config:
admin
Hey Lilly :waving_hand:
Thanks for checking. Yeah it should be working, I have no idea why it doesn’t. I tried with safe mode too but same result. :confused:
If I switch back to use_site_small_logo_as_system_avatar it shows the small logo as expected. But if I use gravatar or custom image avatar it is fallback to letter avatar in notifications.
