Hi Guys
I’ve been getting the time to update your component notice
[Admin Notice] One of your themes or plugins needs updating for compatibility with upcoming Discourse core changes. (id:discourse.header-widget-overrides) Identified theme: ‘Header Icons’.
As a newbie who wrote the original component using the help documents, looking at examples and trial and error. I’m a bit lost.
The post about the changes, Upcoming Header Changes - Preparing Themes and Plugins has assumed knowledge and context that I am lacking. And the help documents Beginner's guide to developing Discourse Themes do not reference the new APIs (and seem a little out of date now
My component adds two icons to the header - one is a link to the Documents plugin’s page, and the other is an icon that changes icon based on a value in a custom field in the settings.
It is currently done via the below in head_tag.html
Any guidance would be valued as i’m completely lost on where to go for this
Thanks
const { iconNode } = require("discourse-common/lib/icon-library");
api.decorateWidget('header-icons:before', helper => {
return helper.h('div.d-header-icons.doc-header-set', [
helper.h('a.icon.btn-flat.doc', {
href:'/docs',
title: 'Documents'
}, [iconNode("book"), "Documents"]),
api.decorateWidget('header-icons:before', (helper) => {
//https://fontawesome.com/v5.15/icons?d=gallery&p=2&q=times&s=regular,solid&m=free
let icon = 'calendar';
let title = 'Open status: unknown';
try {
const cache = JSON.parse(settings.tool_status);
const shutter = cache.tools[4];
if (shutter.status)
icon = 'calendar-check';
title = 'Open since '+shutter.date;
else
icon = 'calendar-alt';
title = 'Closed since '+shutter.date;
} catch (e) {}
return helper.h('div.d-header-icons.shutter-status', [
helper.h('a.icon', {
href:'/calendar',
title: title
}, iconNode(icon)),
</script>
You can see the whole github of my component here: GitHub - bluefroguk1/DiscourseHeaderIcons: This theme component places the Calendar icon + shutter status tick in our Discourse instance bask in my terrible coding attempt lol
