Agenda- en evenementenplugin -> GEEN evenementen om je voor aan te melden
Hi folks,
i have the calendar and events plugin installed in vers. 0,5 and i have a problem with showing the rsvp the message is just empty:
But i can see it in the calendar in the category:
Other users cant see it too:
here are the settings_
thx for assist :wink:
Hmm.. that is weird. I just tested again myself and events appear in the topic normally on my site. Are you updated to latest? Does it appear if you use /safe-mode and disable themes and theme components and unofficial plugins? If you look in the javascript console, do you see any errors?
HI Tobias,
in safe-mode it isnt viewed too with all the settings your named settings.
In the console from developer tools i only got this:
I dont really know how to pic up the post in the dev tools and where to look excatly sry.
Hi André @Nuenni ,
if I see it correctly you have no name tag in your event definition like here
[event start=“2024-12-12 10:36” status=“public” name=“testevent” timezone=“Europe/Berlin” recurrence=“every_month” end=“2024-12-12 10:40” allowedGroups=“trust_level_0”]
[/event]
Thanks for the suggestion, but that does not seem to be related to the problem described in the first post of this topic. @Nuenni have you been able to solve it? If not, I think the next steps are to look at safe mode to see if there are any theme components or plugins that are causing a conflict here.
You shouldn’t need to have the name specified for the event to show up. I just tested it again myself. If you don’t specify the name, it just takes the topic title and uses that as the name for the event.
This event markdown:
[event start="2024-12-12 06:12" status="public" timezone="America/Los_Angeles" allowedGroups="trust_level_0"]
[/event]
shows up in my topic like this:
