Don
21 בנובמבר, 2024, 5:31am
1
Hello
The gpt4o mini seems to have gone crazy and it can’t stop streaming for over 1 hour now. Every time I click the pause button it nothing happens just stop a sec. The temperature has been set too high. Is there any way to stop it? It writes random things all the time.
Thanks
לייק 1
sam
(Sam Saffron)
21 בנובמבר, 2024, 5:37am
4
I do have a repro on the pause issue… having a look… this is certainly a bug. cancel is not canceling.
2 לייקים
Don
5
If I rebuild it will stop or continue after it?
sam
(Sam Saffron)
21 בנובמבר, 2024, 5:38am
6
it will stop if you restart the container
לייק 1
Don
21 בנובמבר, 2024, 5:52am
7
Thanks Sam, it worked! Luckily, it was only the gpt4o mini
sam
(Sam Saffron)
21 בנובמבר, 2024, 5:56am
8
main ← fix-stream-stop
merged 06:51AM - 21 Nov 24 UTC
The cancel messaging was not floating correctly to the HTTP call
I don’t think they can charge you beyond the limit of what they generate, cause it is a bug on their side.
But yeah I regressed this while refactoring, will merge shortly and add a test here.
3 לייקים
Don
21 בנובמבר, 2024, 6:03am
9
I see now, thanks for the fix!
sam
(Sam Saffron)
21 בנובמבר, 2024, 6:52am
10
just merged it, there is a test as well, be sure to play with artifacts
2 לייקים
Jagster
(Jakke Flemming)
21 בנובמבר, 2024, 7:18am
11
Yes they can. Been there.
לייק 1
j.jaffeux
(Joffrey Jaffeux)
נסגר ב־
24 בנובמבר, 2024, 7:18am
12
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
