Kan ai bot streaming niet stoppen
Hello :wave:
The gpt4o mini seems to have gone crazy and it can’t stop streaming for over 1 hour now. Every time I click the pause button it nothing happens just stop a sec. The temperature has been set too high. Is there any way to stop it? It writes random things all the time. :sweat_smile:
Thanks :slight_smile:
oh my… what … where?
In personal message.
I do have a repro on the pause issue… having a look… this is certainly a bug. cancel is not canceling.
If I rebuild it will stop or continue after it?
it will stop if you restart the container
Thanks Sam, it worked! Luckily, it was only the gpt4o mini :sweat_smile:
https://github.com/discourse/discourse-ai/pull/938
I don’t think they can charge you beyond the limit of what they generate, cause it is a bug on their side.
But yeah I regressed this while refactoring, will merge shortly and add a test here.
I see now, thanks for the fix! :slightly_smiling_face:
just merged it, there is a test as well, be sure to play with artifacts :slight_smile:
Yes they can. Been there.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
