cmdntd
(cmdntd)
25 november 2024 om 15:12
1
When uploading to s3, discourse will save backups to the default folder
this makes the default download link of discourse here unusable:
https://domain.com/admin/backups/backup.tar.gz?token=id
must manually edit the above link as follows to use:
https://domain.com/admin/backups/default/backup.tar.gz?token=id
how to configure this problem?
Lilly
(Lillian )
26 november 2024 om 00:34
You might be able to do something like this-Replace a string in all posts
cmdntd
(cmdntd)
26 november 2024 om 16:48
3
Is there any way to limit this to just the backups settings area?
This looks a bit dangerous, because if there is another matching character in the entire database, it will be overwritten:
hooks:
after_code:
- exec:
cd: $home
cmd:
rails r "
Post.where(\"cooked LIKE '%/admin/backups/%'\").find_each do |post|
post.cooked = post.cooked.gsub('/admin/backups/', '/admin/backups/default/');
post.save!;
post.revise(Discourse.system_user, post.cooked, bypass_rate_limiter: true);
rails r "
Upload.where(\"url LIKE '%/admin/backups/%'\").find_each do |upload|
upload.url = upload.url.gsub('/admin/backups/', '/admin/backups/default/');
upload.save!;
Lilly
(Lillian )
26 november 2024 om 23:30
5
sorry i misread your post earlier thinking you were talking about a migrated forum links for some reason.
this seems like something isn’t set up properly.
has it always been this way or did you change something?
This guide explains how to configure automatic backups for Discourse, including storage options on local servers and S3-compatible storage.
Learn how to set up automatic backups for your Discourse platform.
This guide covers configuring automatic backups, storing them on local servers or S3-compatible storage, and managing storage retention options like Amazon Glacier.
Configuring automatic backups
Navigate to /admin settings.
Select the Backup section.
Set backup_frequency to …
cmdntd
(cmdntd)
27 november 2024 om 13:38
6
I 'm trying to setup with seaweedfs s3. But it seems not to be here:
This topic covers how to configure some common S3 compatible Object Storage providers (S3 clones). See Set up file and image uploads to S3 for more details about Amazon AWS S3 configuration, which is officially supported and used internally by Discourse for our hosting services.
Provider
Service Name
Works with Discourse?
Amazon AWS
S3
Yes
Digital Ocean
Spaces
Yes
Linode
Object Storage
Yes
Google Cloud
Storage
Yes
Scaleway
Object Storage
Yes
Vultr
Obj…
