화이트라벨 앱(리브랜딩)에 푸시 알림 구현 방법
We have customized the Discourse mobile app to function primarily as a webview that loads the URL of our community, with all interactions managed within the webview. Since there are no redirected authentication screens in our implementation, how can we integrate push notifications into this app?
We have already created a Firebase project and added the google-services.json file for Android, and similarly, APNs has been set up for iOS. Do we need our own backend server to trigger notifications? How would this backend communicate with our forum—for instance, how would it determine when to send a notification and which user should receive it?
Use the one-signal plugin.
https://github.com/pmusaraj/discourse-onesignal
(This was just archived but probably saveable with a fork)
See: Whitelisted Discourse app with Push Notifications via OneSignal. (I know from experience the API is likely to need tweaking as probably out of date)
Yes, correct, that plugin is archived, because I haven’t used it in years and I don’t know if it works at all. (In particular there’s a login flow tweak in there that is probably no longer functional.) In any case, forking is an option.
We use Amazon SNS to do the same thing now, using: GitHub - discourse/discourse-amazon-sns · GitHub
I am realizing now that it doesn’t have any documentation. It shouldn’t be too hard, the plugin only has a few settings. I’ll make a note to write a documentation topic, but @Mohsin136 if you’re familiar at all with SNS, you can give this a shot. And if it works, I would gladly accept your rough notes as a source for a documentation topic (it would save me some time).
