Themaontwerp bewerken
Whats the actual way to edit the theme is it possible? I’m self hosting the forum and want to make changes to the theme, how to do it? Not through additional css, but is there any other way to make proper changes to it?
PS: I’m using DigitalOcean
Hi,
What modifications do you need? Please let us know so we can assist you better!
You can usually change your theme through theme components or plugins.
If you are not familiar with Theme and Theme components, this is a crash course here:
You can look at a list of the official theme components here:
Other topics on this subject can be found here: Topics tagged customization
You can also check out Theme component or Plugin sections :slight_smile:
If you don’t want to write any CSS, you can edit the theme by changing its colour schemes.
From additional CSS I mean I don’t want to make changes in the dialogue box of CSS instead in the main files, so is there some extension like file editor or something as in WP?
Thanks for sharing, also is there something like a File Editor Extension or something available through which I can easily make changes to the code or is there any alternative to the same?
I mean, you could make a new repository on Github and connect your IDE to that, and then edit files like common.scss etc.
Or, you can go to Admin > Customize > Themes and make a theme and edit them/edit an existing theme.
Thanks that helped
