토픽 요약 창 고정하기
When the Topic Summary contains links to specific posts, it’s helpful to click on the links for more detail. On https://meta.discourse.org, when you click, the summary window remains open, which is great. But on my site and https://discuss.ai.google.dev, clicking on a link dismisses the summary window, which is cumbersome. What’s the secret to make it stay open?
1개의 좋아요
Can you explain what you mean by the topic summary window? I assumed you mean the modal that pops up when you click the summarise button, but on your site that is moving as expected.
1개의 좋아요
We had a bug where it would close on click if the post was on another “page”, but I believe we fixed that. Did you try updating your site ?
1개의 좋아요
I’ll use your screenshot as an example.
On meta, if I click on Monalika’s comment, it would navigate to that comment, and the “Topic summary” modal would stay open, so I could then click on Shubham’s comment, then afirstenberg’s, etc., so I could easily browse the most important posts.
On my site, and at https://discuss.ai.google.dev/, if I click on Monalika’s comment, it would navigate to that comment, and the “Topic summary” modal would close.
If you can’t reproduce that, it may be related to a lot of errors in my console- 429 too many requests, related to rsvp.js and getting user badges. They happen when I click the links. Here are just the first few:
Yes, I did that today.
1개의 좋아요
Ah right – I thought you were referring to the Google site, not another one. What version are you running?
1개의 좋아요
Oh I see what this is, this happens on long topics.
If the “section” of the topic is not currently loaded then we shut the summary down on click.
Repro is:
  1. Have a topic with 30 posts
  2. Go to post 30 direct from home page
  3. Show summary
  4. Click on a link that goes to post #1
  5. Summary closes
Not 100% sure how to sort this out… maybe @keegan has some ideas.
3개의 좋아요
Does that also explain the 429 errors getting the user badges, or is that a separate issue?
1개의 좋아요
That means you are using the cursed theme component “Post Badges”.
@david recently changed it to make it perform well, but you need to update Discourse to latest to get it.
1개의 좋아요
Yeah, this is a regression of the new design. We reported it internally back in August, but looks like no one was assigned. Will prioritize it.
4개의 좋아요
This has now been resolved by @awesomerobot :tada:
https://github.com/discourse/discourse-ai/pull/992
Testing on this topic shows that it works
4개의 좋아요
This topic was automatically closed after 3 days. New replies are no longer allowed.
