הודעת שגיאת ההרשמה מבלבלת: "סיסמת המשתמש זהה לשם שלך"
סיכום מבוסס בינה מלאכותית
The Discourse signup dialog’s error message “User password password is the same as your name” is confusing. Jay_Boyd reported this issue, which occurs when a user mistakenly enters their verification password in place of their username. The error message is unclear due to the repeated word “password”. @Jay_Boyd has experienced this issue with two users who required admin assistance. zogstrip was able to reproduce the issue and requested jancernik to review. The issue has been fixed in a commit by jancernik.
Typically when you create an account you type the password and then have to verify the password. The discourse sign up dialog is a bit busy with field names and field descriptions and could be confusing if you attempt to quickly fill it out and mistakenly enter your verification password in place of the Username. If you do that and then click submit you get an error at the top of the dialog that is confusing as it states “User password password is the same as your name”. Password is repeated here in the error, it would be clearer and easier to understand if it was not repeated. I’ve had two users (both with English as a non-primary language probably) that got this error and required admin assistance to determine the problem.
5 לייקים
Thanks @Jay_Boyd for the report. I can indeed reproduce
@jancernik mind having a quick look? At the very minimum we should fix the error message.
4 לייקים
Hey @Jay_Boyd, thanks for the report! This issue has been fixed in the following commit:
https://github.com/discourse/discourse/commit/ca0ea3d201be981b9bcdc236c0b25b6623b611a3
4 לייקים
This topic was automatically closed after 4 days. New replies are no longer allowed.
