משוב על תמציות בינה מלאכותית, סיכומים קצרים על רשימת נושאים
סיכום מבוסס בינה מלאכותית
Saif announced the rollout of AI Gists, short summaries displayed in the topic list to help users quickly grasp topic content. The initial feedback request focused on utility, usage frequency, and toggling behavior. Several technical and UX issues emerged from the discussion:
  • Technical Setup & Visibility: markschmucker reported missing gist icons despite correct settings. Moin pointed to the #documentation, and Saif clarified that Gists are currently limited to Meta and a few sites, with wider rollout pending further refinement of settings.
  • UI/UX Improvements: NateDhaliwal requested that the gist button toggle between view types directly, rather than opening a model selection menu, to save time. Saif acknowledged this as valid feedback. Canapin noted a naming inconsistency where the “regular” view is called “compact” even when showing excerpts, which Saif suspected was a compatibility issue.
  • Summary Quality & Strategy: simon critiqued current AI outputs as failing to meet “human-level” writing standards, often cramming too much info into single sentences. He argued the goal should be providing context (e.g., restating the user’s question or defining a term) rather than exhaustive summaries. Saif agreed, noting the difficulty of compressing complex topics into 1-2 sentences.
  • Usefulness Debate: Canapin expressed skepticism, arguing that clear titles usually suffice and summaries add little value unless paired with different page layouts or longer excerpts.
  • Theme Compatibility: satonotdead reported the view toggle button missing on the Horizon theme. After initial debugging by sam, satonotdead identified that Discourse renders gists only in “classic cells,” which Horizon replaces with special cards. They shared a custom workaround to enable gists in Horizon, inviting further improvements.
You might have noticed that short summaries have been enabled on Meta.
The image shows a screenshot of the Discourse forum, displaying a list of topics with details like replies, views, and activity. (Captioned by AI)
This will result in the topic list showing short summaries of the topics to help you get a quick overview.
Any feedback is welcome!
  • How are you personally using this feature?
  • Do you find any value in seeing the short summaries?
  • How often are you toggling this on or off?
  • What else would be helpful here?
7 לייקים
The gist icon is not showing on my site. I’ve set ai summary gists allowed groups to “everyone”. I’m running 3.4.0.beta3-dev. Did a hard refresh. Do I need ai bot github access token, and can you elaborate on what that does?
EDIT: I see How to enable compact vs expanded topic view now. So I guess you’re just looking for feedback on meta at this time.
The Documentation is here
לייק 1
Right now Gists are only available on Meta and a handful of sites. Once it is ready we will be rolling it out more widely. Will update the doc with more info as we are rethinking some of the settings
2 לייקים
I have a request: can clicking on the gists button switch to the other type, without opening the model? Since there’s only one other option, it is time-consuming to choose the only other option.
לייק 1
Yeah, I believe we’ve heard this feedback before @awesomerobot. Certainly, an idea for us to consider
לייק 1
It might be useful to define some human generated benchmarks for the summaries, then keep iterating prompts until the results meet or exceed those benchmarks.
A couple of examples:
Gist for Understanding and managing bootstrap mode
Discourse’s bootstrap mode is a special state facilitating community growth, automatically adjusting user trust, communication frequency, and directory updates, and can be identified through the “Getting started” button or staff action logs.
Gist for a bug topic:
Forum theme is causing the user menu visibility issue, which can be tracked and solved, making it a manageable problem to fix despite being a little challenging.
I don’t think either of those excerpts are approaching human level performance - with human level performance defined as what can be achieved by a good writer. My guess is that the problem is that the LLM is being given an impossible task by being asked to fit too much information into a single sentence.
The primary goal of the excerpt should be to give users some idea of what to expect in the topic. It doesn’t need to do much beyond that.
It’s likely that the LLM that’s generating the excerpts needs to be aware of the context of the topic. For example, for the bootstrap documentation topic, I’d expect a simple definition of bootstrap mode. For a topic where the OP is a user generated question, the excerpt might just restate the question in terms that are likely to be understood by the site’s users. A topic initiated by a highly technical user might have an excerpt that uses a few technical terms, in order to attract the right audience to the topic.
3 לייקים
Not really. Most of the time, a title accurately describes a topic’s content (that’s the desired goal, after all). If a title is too vague and can be improved, a T3+ or a staff user will often rewrite it.
But let’s elaborate a bit. I could see a better use of it with a different page presentation and a longer summary.
לייק 1
This :100:, I think this is the goal. For all the reasons you mentioned it can be a difficult task for LLMs to go through the whole topic and understand the context → spit it out in 1-2 sentences
2 לייקים
I don’t think it was mentioned somewhere after searching on meta and ask.discourse.
The toggle feels weird for sites or themes that display regular excerpts.
The image shows a user interface for a Discord-themed image page with a menu on the left and a community settings interface on the right. (Captioned by AI)
The “regular” view is called “compact” even when it shows an excerpt, and switching from one to another is a bit superfluous.
2 לייקים
Might be a compatibility issue as you’ve mentioned, thank you for reporting it
2 לייקים
The button for changing the view is gone. May I know the method to enable summaries again? :melting_face:
I’m on Horizon and probably missing something, for sure.
Are you sure, it should be in Horizon:
Time passed and I remembered this post while searching, before publishing what is currently my solution below.
Discourse renders the gist only in the classic cell of the lists, which are replaced by Horizon from the special cards.
Perhaps it is not the most elegant solution but it works and I am open to improvements or suggestions:
