Emoji's worden niet weergegeven in de inhoudsopgave
Hi,
I use some emojis un my titles, but in the TOC they are not displayed.
For instance:
### 📣 Aide chapitrage vidéo des mini-webinaires
displays as
in the toc.
Is there a way to display emojis?
No solution for that?
There’s a solution. Use unicode emoji, and wrap them with backticks `.
In the table of contents, the title will be stripped of backticks, but keep the unicode emoj.
### Test 1
### `📣` Test 2
### Test 3
The drawback is that it looks odd in the post:
If you want the visually perfect solution but slighly convoluted:
### Test 1
### <span data-title-emoji>`🧑‍💻`</span> Test 2
### Test 3
With this CSS
span[data-title-emoji] code {
    background: inherit;
Renders:
:information_source: [wrap] won’t work for this purpose in a title, you must go with <span>
Great !!!
Big thanks, it works :folded_hands:
