Samenvatting - Gists
:bookmark: This guide explains how to enable and configure Gists, which is part of the Summarize feature of the Discourse AI plugin.
:person_raising_hand: Required user level: Administrator
Gists are short AI summaries to help you get a quick overview from topic lists.
Features
  • Auto backfills short summaries of topics
  • Toggleable between compact and expanded (with AI summary) topic views
  • Available for all topic views, i.e - hot, latest, top etc
Enabling Summarize
Prerequisites
You must configure at least one Large Language Model (LLM) from a provider.
To get started you can configure them through the Discourse AI - Large Language Model (LLM) settings page.
Configuration
  1. Go to AdminPluginsAIFeatures tab, select Summarization, and make sure AI summarization enabled and AI summary gists enabled are checked.
  2. Switch to the Agents tab and edit the Summarizer (short form) agent to use your LLM as the Default language model, and ensure the agent is enabled.
  3. (optional) Increase ai_summary_backfill_maximum_topics_per_hour to backfill gists for older topics, control how far back to backfill via ai_summary_backfill_topic_max_age_days, and set a minimum topic length for backfill via ai_summary_backfill_minimum_word_count (default: 200 words).
why is this? is it enterprise-only? if so, the OP should be updated.
it seems to be working great for self-hosted forums.
Is there a way to make gists visible by default? Currently the default layout is “compact”. I was hoping for a setting at /admin/config/interface.
