Toegang tot de vastgezette openingsbanner
Hello,
I forgot the way to change the message into the pinned opening banner as below
I’m the admin of the website Libertysim.net - Simulation Aérienne Spatiale - Space Flight simulation
That might be something trivial but I’m unable to find the solution from the search
Hi @Wildweasel :wave:
looks like it’s this topic here:
if you go to the admin wrench on the side of the topic post, it should allow you to unpin it. (Or you can just edit it as you would edit any post as admin, to make a new version.)
Thank you very much. I looked for it into the admin parameters instead of the topics
For future reference, I just went to the forum and did a search for some of the text string in the banner post and found it right away :slight_smile:
