Ondersteuning voor zip-uploads naar forums
Have a question about Discourse’s ability to support zip uploads to forums. Looking to create a repository for designated users to upload playbooks and product content to a specific repo forum page. Is this possible using the Discourse platform? Thank you
You can add zip to the authorized_extensions setting and people can upload them. There isn’t any support like being able to see what’s inside them, though
Thanks @pfaffman. can the following scenario be supported in the Discourse platform? User posts with exact instructions of what’s included in the zip file. zip file is linked to the post. Community Admin’s like myself are able to see the post and approve it or not approve it before going live to the entire community. Would want to do some sort of sani check prior to releasing to the larger audience. Thank you for your help with this!
Sure, you can set up Moderator approval required in the category settings.
Thank you @tobiaseigen. Super helpful!
