האם יש דרך למנוע את ההודעה FAILED באמצעות כלי בדיקה (inspect tool)?
סיכום מבוסס בינה מלאכותית
The discussion revolves around preventing the “FAILED” message via the inspect tool. bob_the_tomato initially asked for help, and NateDhaliwal provided a JavaScript code workaround for regular users. Despite some confusion, Moin and NateDhaliwal clarified that the code can be run in the browser’s JavaScript console, and there is no need for GitHub. Jagster also addressed bob_the_tomato’s misconception about laptops being non-functional PCs. Eventually, Moin provided step-by-step instructions on how to use the code, which bob_the_tomato successfully followed. Additionally, NateDhaliwal shared another resource for unstarving all badges on mobile devices.
Continuation from this topic
Is there any way to prevent the FAILED message through inspect? I am not an admin, nor can I use the mod thingamabobers.
Help is appreciated!
Did you see the linked post?
I can’t be an admin.
Wait, I mean I can’t contact the admin, idk how I got that lol
But you are “a regular user” aren’t you?
Yes, but I can’t contact the admin
and I can’t use github
And how does that prevent you from using the workaround for regular users that was quoted above?
I guess you use a browser, so you can search how to use its JavaScript console and use the workaround for regular users.
Someone told me, that github only works in fully functional pc’s, and I’m just on a laptop.
@bob_the_tomato The code I quoted can be run by Inspecting the page and running it in the Javascript Console. It is made for regular users to use.
AFAIK there is no Github element to the code.
Laptop is a fully functional PC (even then when it is a mac, but otherwise Apple has its own policy thru all devices).
But why you can’t contact an admin? Are they hided it? Use moderators as relay then.
Hello!
Thanks for the help!
But mah tiny brain is not braining, I can’t see how to download the code.
I’ve tried downloading it to the browser, but I can’t seem what to do now. When I open it, it brings me to textEdit.
I still don’t understand what you are trying to do. Why do you need GitHub, and why do you download the Ruby file?
  1. You copy the code that was shared in the other topic:
  2. You open the browser console using, for example, F12 (or another way to open the console. A search engine can help you find guides on how to do that in your browser).
  3. You paste the code you have copied into the console:
  4. You execute the code by pressing Enter.
Thank you so much! When I went into inspect I saw the console option, and I ran the code! Thanks again :D
If you are mobile an this occurs on another forum you’re an admin on, you can use this TC:
