Starting today, December 12, the date is missing on the side scroll bar.
Here on Meta, the date is visible
However, on my forum, the date is missing. This is troublesome on some of the longer threads.
There are two situations where the date becomes hidden —
Megatopics - when a topic has over 10,000 posts some information is reduced to improve performance
Post count wrapping onto multiple lines (the case above) - this is because the amount of content on the scroll handle can overlap other elements like the back button and the date at the bottom of the topic
The second case can be undone with CSS:
.timeline-container .topic-timeline {
.timeline-ago {
overflow: visible;
.timeline-scroller-content {
overflow: visible;
One thing we can consider in the future is improving this case, perhaps we can only hide the date when the timeline is at the bottom ![]()
I also noticed that the side bar is narrower than it was yesterday (or maybe the day before), I have no screenshots to support this, but it seems to be closer to the edge than it was.
There’s a ton of white space between the scroll bar and the posts, could it just be widened?
Yeah the handling of the width there can probably be improved too — though in this specific case with the difference from yesterday is a bug because there’s a notification level button that went missing (should be fixed the next time you update)
So this is something that can be fixed with an update and I don’t have to find someone to do it?
Yeah the recent narrow bar issue should be fixed if you update
It’s back!
Thanks so much!!!
