Mark unread marks the latest post and notification as unread even if these are unrelated
I was a little confused when I used the mark unread feature recently. I clicked the button at the bottom of the topic so I could get back to it later.
At first, everything seemed to work as expected: the topic was added to /unread, I had an indicator in the sidebar, and there was an unread count next to the topic. However, I noticed there was also an unread notification about a like.
When I opened the topic, all the unread indicators disappeared, but the one for the like remained.
It turns out this is connected to a post from May: DiscoTOC - automatic table of contents - #434 by Moin. The notification about the like was also created in May.
How is “mark unread” expected to work? Should it mark the last post in the topic as unread? Should it mark the latest notification as unread? Should both happen if they are about the same post, for example, because you were mentioned in the latest post? Should both happen if the notification is about a post you wrote and received a like six months ago?
I’m an avid Defer (how it used to be called :sweat_smile:) user and this quirk has always bothered me.
Whenever there’s a mention / quote / assign (or anything that triggers a notification) in the topic, it will be re-triggered when you click “mark unread” :slightly_frowning_face:
I’ll have a quick look :eyes:
Was made aware that this was indeed a feature :sweat_smile:
Marking a topic as unread will re-trigger the last notification in that topic :man_shrugging:
So I move this to Contribute > Feature and ask for likes to be excluded?
(and someone should tell ask.discourse that it’s a feature :slight_smile: )
