Inklapknop werkt niet op profielpagina (mobiel)
The collapse button on the profile page isn’t working on mobile. I’ve tried switching themes, but the issue persists. It could either be a bug or a UI/UX theme issue, but I just wanted to bring it to attention.
What device / OS / browser are you using?
Have you tried using safe mode to disable themes & plugins?
Can you reproduce here on meta? Or on try.discourse.org?
I’m on ios, attaching a vid for your quick reference.
I can also reproduce this here on Meta using my Android phone.
I must be blind or something but I can’t see that Collapse button :astonished:
What user profile / page are you seeing this? :face_with_monocle:
+1 Tried it on Android, and got the same issue on desktop too. I checked it on Safari, Chrome, and Firefox.
https://meta.discourse.org/my/activity
Actually, the button works once. When you collapse it first because it is expanded, you cannot expand it again.
On your profile page, after you click on expand.
Right, on “my” profile :man_facepalming:
Can reproduce. Will fix :hammer_and_wrench:
Thanks for the report @MihirR - will be fixed by
https://github.com/discourse/discourse/pull/30272
Yaaay, thanks for working on it :slight_smile:
Edit: It was fixed by the team.
This topic was automatically closed after 14 hours. New replies are no longer allowed.
