| Summary | Topic Map Stats Icons | |
| Preview | Theme Creator | |
| Repository | GitHub - VaperinaDEV/topic-map-stats-icons: With this theme component you can change the topic map stats texts to icons. | |
| Install Guide | How to install a theme or theme component | |
| New to Discourse Themes? | Beginner’s guide to using Discourse Themes |
Install this theme component
Hello ![]()
With this theme component you can change the topic map stats texts to icons. It adds the icons with CSS.
Default Topic Map
With theme component
Settings
It contains two theme settings where you can set up the stats icon and also a setting for change the numbers color of the setted up stats.
Icons:
I keep only the topic map related icons.
Regular
| Name | Icon |
| chart-bar | |
| eye | |
| heart | |
| thumbs-up | |
| share-from-square | |
| user | |
| circle-user |
Solid
| Name | Icon |
| chart-bar | |
| chart-line | |
| chart-column | |
| eye | |
| heart | |
| thumbs-up | |
| link | |
| share | |
| share-nodes | |
| user | |
| circle-user | |
| users |
So you can make it for example:
With regular icons:
It’s up to you ![]()
We can add more icons from FontAwesome 6 Free, Material etc… if you wish…
