Persoonlijk bericht aan mezelf maken voor het maken van notities, zonder zelf de gebruikersnaam met de hand in te vullen
Creating personal message to self for taking notes is being discussed. Jun wants to add a direct link on the homepage for taking private notes, sending to self, without requiring users to fill in their own username. Jun referenced a guide on creating pre-filled personal message links, but is looking for a way to pre-fill the username for every user with their own username. Moin and Jun discussed the possibility of such a link, but it seems it’s not possible at the moment. Alternatively, Jagster suggested using a private category or guiding users to use their devices’ tools for note-taking. Jun emphasized the need for a convenient way to write and modify drafts, and thinks using a message could be sufficient, but filling in one’s own name every time is inconvenient. Lilly expressed uncertainty about implementing this for every user.
I’d like to add an direct link on homepage for taking private notes, sending to self.
I’ve read creating-pre-filled-personal-message-links.
https://try.discourse.org/new-message?username=rudy
Is there any way to pre-fill username for every user, just with own username(like rudy)?So users needn’t search and fill their own names by hand.
not sure about doing it for every user…
There was some discussion about that in Allow multiple ‘new topic’ drafts - #33 by Aizada_M
I don’t think such a link is possible at the moment
Thanks. I’ve already posted the guide above. I wonder if there is a way to pre-fill username in receiver for logined user, just own name.
I took a different path. I guided my users on how to effectively use tools to make notes using their devices.
Multiple drafts won’t fix that, because publishing and notes are fundamentally different things. I have a few such power users, and for them (and myself), I created a private category. But that can’t be a general solution.
For each user, he/she may like to write drafts with different topics and modify them sometime. Publish or just keep notes. I think message is enough to do this, but it’s inconvenient to fill own name every time.
