איך לרענן את CSS באפליקציית Hub ובאפליקציית iOS A2HP
I changed the font on my forum but the Hub app and the A2HP app still have it in their heads that it’s the same. It works ok on normal browsers.
And you closed and re-opened that forum in the Hub? That is only way to reload.
Yes, and swiped up to close the app entirely, turned my phone off and on…
Maybe it’s a problem with my CSS! Though it works on my PC Chrome browser and iOS Safari.
Update: Your sureness made me check and I now do think it does have something to do with my CSS.
It was indeed my CSS. I’d copied and pasted something from this forum which works to change the site font, but doesn’t work fully while I’m using the dark-light mode toggle. I worked out a different way. Thanks for the steer.
