I ran ./laucher app rebuild this morning (there are other ways to upgrade too, like the GUI).
This is the current detail given on the Admin page.
My Discourse has a very active calendar. All the pre-defined event start and end times reset from local time to UTC. That has a significant impact on my community.
That event was defined as 9am → 5:30pm.
Can you show us the raw for that post where the event is defined?
Actually, the event is just displaying event times as UTC. Clicking (or perhaps hovering) the event shows this.
Very weird. I’ve now seen a variety of cases:
As another user, the event visited shows local time.
As admin, an event was UTC. Refreshed. Event updated to local time.
As admin, chose another event. Local time shown.
As admin, that Dec 22 event still showing as UTC.
As another user, that Dec 22 event displaying as local time.
I’m glad I have a screenshot or I’d think I was going crazy.
[event start="2024-12-22 09:00" status="standalone" timezone="America/Toronto" end="2024-12-22 17:30" reminders="bumpTopic.3.days" allowedGroups="trust_level_0"]
[/event]
At a guess, these posts probably needed a rebake and your server is working through them and rebaking them with updated formatting.
On a post that still looks “wrong”, if you force a rebake:
does it look right?
I’m too late. I refreshed the page of my example and the event updated to local time.
If I find another problem event, I’ll try your suggestion.
I will add that my update was complete more than 5 hours ago. It’s not a big site. It’s also not a powerful server, but it is adequate.
j.jaffeux
(Joffrey Jaffeux)
12월 20, 2024, 6:03오후
8
This is a problem with local dates, sometimes they are not applied to the calendar, we are aware, I will try to fix this in the near future.
2개의 좋아요
I can now confirm that a rebake did result in an update.
As admin, I found this event…
and then used the Rebuild HTML option and had this result…
1개의 좋아요
The Rebuild HTML option doesn’t seem to be necessary. I can get a corrected result just by refreshing the page. It’s annoying though, because navigating from the Upcoming Events calendar to the event does give me the incorrect times. Members expect to see a reliable result every time.
I don’t think I’ve found a case of incorrectly displayed times for any user other than admin.
j.jaffeux
(Joffrey Jaffeux)
1월 6, 2025, 8:47오전
12
3개의 좋아요
j.jaffeux
(Joffrey Jaffeux)
에 닫힘
1월 9, 2025, 8:48오전
14
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
