Discourse Docker에서 갑자기 발생하는 HTTP 403 오류(“BAD CSRF”)
We’re using Discourse Docker and getting HTTP 403 since yesterday (2024-12-21) when trying to login or (for those already logged in) to post a message. The error response is ["BAD CSRF"], which makes me think this security fix may have caused this regression:
https://github.com/discourse/discourse/commit/438abaa50418261f60799f118d90580b36448cdd
Is anybody else experiencing these?
PS: The Discourse instance exists since 2020, and is updated automatically every night.
1개의 좋아요
Maybe this will fix it in 3.3.4?
https://github.com/discourse/discourse/pull/30410
See also:
2개의 좋아요
Can you try it out?
1개의 좋아요
@sam Thank you, I just verified and I can log in again in 3.3.3 + 1, so the PR mentioned above resolved the issue.
4개의 좋아요
Thanks for checking!
