שאלה על מילוי הקטגוריה בתגיות מסוימות
סיכום מבוסס בינה מלאכותית
The discussion revolves around creating a category called “Videos” that automatically populates with posts tagged “video” or “videos”. Truthseeker asks if existing topics with the tag can be automatically moved to the new category. thoka clarifies that topics can only belong to one category, so they must be manually moved or referenced. NateDhaliwal confirms that automatic movement based on tags isn’t possible. Canapin explains that while automatic moves aren’t supported, topics can be bulk-moved via the admin interface or CLI. NateDhaliwal suggests using a permalink redirect from the category page to the tag page, but Truthseeker notes this didn’t work as expected.
Sorry if this is a dumb question I tried to search but didn’t get what I was looking for.
So say you have a forum and posts, and some posts are video related, and have a “video/videos” tag randomly in different categories perhaps
I want to create a new category called “Videos” , and this category will auto populate with anything labeled with the videos/video tag automatically
Can someone post link to instructions if already exist or instruct me how pls?
You already have this functionality: If you click on the tag, every topic labeled with the tag will be shown.
A topic can be assigned only to one category. If you still want to have the special “video” category, you can either a) move your topics there or b) create new posts with references to the original posts.
I think OP meant when they create the Videos category, existing topics with the videos tag will automatically be added (moved) to the category.
But this is correct. Unless the automatic adding changes the topic’s current category to the Videos category.
Do you want the topics to be moved to the new category, or available in the new category somewhat like a crosspost? The latter is not possible in Discourse.
As far as I know, there’s no setting to automatically move a topic from one category to another based on its tags.
If you want t move XX existing topics manually, you can select them after filtering them by tag, then bulk move them through the interface.
If you have many topics to move, you can use the command line: https://meta.discourse.org/t/administrative-bulk-operations/118349#p-582358-move-all-topics-with-a-specific-tag-to-a-single-category-15
You can also use a webhook to move a topic in a certain category when it is posed based on its tags, but I’d say it’s better not to allow certain tags to be used outside this category.
At the least – you know when you click a tag it takes you to the page with all the other same tags? I need for someone to be able to click a category , and take me to that list of tags. It’s for presentation, readability, navigation purposes.
I know I can limit tags to certain categories but that’s not what I’m after
Is that possible? Just for a single category
Meaning I click a Category, and a takes me to the tags page with tags “Videos” , but when I click Category, and only for that category
I guess i’ll have to find a different solution
Maybe you could do a custom redirect such that /c/videos will redirect to /tag/videos. You can use Permalinks for this (Admin > Customize > Permalinks).
Really good idea , I tried but it didn’t work :frowning:
tried /c/category to tag videos
tried full url to tag videos
didn’t work, that actually would solve the issue I think
Thanks
