Glimmer의 주제 목록 모드가 목록에서 해결됨 체크박스를 숨깁니다
I’m not sure what, but looks like something Looks like the glimmer topic list mode setting is hiding the topic solved status in the title line of Topic list pages on Meta - the code for the solution checkbox goes missing when that setting is enabled (thanks @Moin for pointing out which setting was doing it).
Meta
Topic list view:
Topic view:
Console:
On my hosted instance, where it is displaying as expected with Glimmer topic list mode disabled.
I am seeing it in multiple browsers, mobile and desktop, on my Macbook and Linux machine, iphone and ipad.
8개의 좋아요
Oh yes, I was also wondering why that Meta topic didn’t have the checkbox in the topic list. Android, can repro.
3개의 좋아요
This will make the ‘auto’ glimmer-topic-list-mode aware of the problematic modification:
https://github.com/discourse/discourse/pull/30496
Once merged, that’ll auto-disable the glimmer topic list on Meta. Then we can follow-up with a fix to the solved plugin. (might need to add a new transformer API to core to support this use-case :eyes:)
6개의 좋아요
이제 정상 작동합니다.
2개의 좋아요
