נכשל עם חזרה #<process::status: pid="" 144="" יציאה="" 128=""></process::status:>
Dear Discourse Community Members,
I am encountering an unresolved error while deploying a Discourse forum on an Aliyun server in China. The error message is as follows:
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
' failed with return #<Process::Status: pid 144 exit 128>
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git reset --hard", "sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  if [ $(git rev-parse --is-shallow-repository) == \"true\" ]; then\n      git remote set-branches --add origin main\n      git remote set-branches origin $version\n      git fetch --depth 1 origin $version\n  else\n      git fetch --tags --prune-tags --prune --force origin\n  fi\n'", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n      git pull\n  else\n      git -c advice.detachedHead=false checkout $version\n  fi\n'", "sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
0ae30c93e953921c82004a93bce079b8b85b5b6bf6e4d42968a0de6e16a2d684
I suspect it is a network issue, as accessing GitHub in China may be restricted. I have tried configuring Docker to use Alibaba Cloud’s mirror, but the problem persists.
Could someone please help me resolve this issue? Thank you very much!
This topic may contain helpful info
Also how I found this topic
In Search use keyword “Aliyun”. There looks to be possibly a guide there in Chinese in the search results. Another keyword for search that may also have info is “Great firewall” iirc
As error message mentions the error is likely higher up than what you copied. Scroll up and look for errors.
Can you check the steps from here?
Especially the part on “Optimization for China’s Network Environment”
4 לייקים
Thank you so much for successfully solving my problem! I really appreciate your help and expertise.
On another note, it’s incredibly frustrating dealing with China’s internet walls. They really hinder access and freedom online.
Thanks again!
3 לייקים
