בעיות עם מסד הנתונים?
Hey gang.
Just did a backup of my DB (DB only), and I am attempting to load it into a PostyGreSQL DB for analysis, however I am getting errors such as those shown in the screenshots. What am I doing wrong?
Working on New Year’s Eve :fireworks:
Kidding aside, you should be able to load the backups directly into a fresh database with psql - it might be the tool you’re using doesn’t like the syntax?
What tool are you using and what versions of PG syntax does it support?
