זמני טעינת עמודים איטיים מאוד (40 שניות) בהתקנת Fresh Discourse
Hi everyone,
I recently set up a Discourse instance following the official installation guide on a lightweight cloud server. I’m experiencing severe performance issues with the initial page load, taking around 40 seconds. However, once loaded, navigation within the site becomes much faster.
Here is my self hosted discourse
Server Specifications:
  • CPU: 2 cores
  • RAM: 4GB
  • Storage: 40GB SSD
  • No other services running on this server (dedicated to Discourse)
Installation Details:
  • Fresh installation using the official Docker setup
  • Followed the standard installation procedure from the documentation
Installed Theme and Plugin
  1. Material Design Theme
  2. Gamification
  3. Solved
Current Issue:
  • Initial page load (cold start) takes approximately 40 seconds
  • Subsequent navigation within the site is much faster
  • The server is dedicated to running only Discourse
  • The server specs should be sufficient according to the minimum requirements
Has anyone experienced similar issues or can suggest potential solutions for improving the initial load times? Are there any specific configuration settings I should check or optimize for better cold start performance?
Thank you in advance for any help or guidance!
3 לייקים
Do you experience the same issue in safe mode, and if you completely remove the plugins from app.yml? Is there any useful information in the network and console tabs of your browser dev tools when the slow loading occurs?
Also,
The reasons for the slowdown might differ, but the topics contain suggestions for helping with the diagnosis.
2 לייקים
