Turn digest back on for users that have been suppressed
The discussion revolves around reactivating email digests for users who have been suppressed due to inactivity, particularly in cases where important community events occur. Amicable explains that users are automatically suppressed after 180 days of inactivity, but may miss critical updates during significant events. They seek a way to selectively re-enable digests for specific groups without direct messaging, which could cause conflict. NateDhaliwal suggests triggering digests based on topics and groups, aligning with the need. Amicable emphasizes the goal of quietly reintegrating inactive members into discussions. pfaffman provides a Rails-based workaround to manually reset digest settings for group members, though it’s noted as potentially unreliable. The community seeks a more robust admin-controlled solution for selectively reactivating digests.
We’ve an instance that, for some, isn’t used much unless and until something very important happens. After x days (as set in the admin UI, default 180) they get their email digest suppressed. But when a once in a decade event happens, they miss important discussion that’s suddenly relevant for them.
We don’t want to email them directly. Is there a way to switch digests back on for them via admin in this use case? Either all of them or ideally selectively, filtered by which group they belong to. Or even individually.
If there isn’t such a method, it’d be great to have!
So something like when there is a new topic (say, about the event), in category x, and they are in group y, send an email digest?
Yes, that’s the general idea. Right now I can only think of a workaround where the user is impersonated and reignited. But that’s far from ideal.
In our use case, something polarising has happened within our community. We have many silent members that would find information about it useful so they can make their own real world decisions.
As admins, we don’t want to stir things up by direct messaging (as that would antagonise the protagonists). But receiving digests again would be a perfect way to get them back into the conversation. The ideal would be for me as admin to select all members in a group and have all their digest triggers reset.
You can do it in Rails, something like
group=Group.find_by_name('mygroup')
group_users=GroupUser.where(group_id: group.id)
group_users.each do |gu|
   u = User.find(gu.user_id)
   op=UserOption.where(user_id: u.id)
   op.email_digests = true
   op.digest_after_minutes = ???
   op.save
The above code was generated by a human, who may have been hallucinating. Use at your own risk.
