Fragmenten verdwijnen uit lucht thema
It appears with this change:
https://github.com/discourse/discourse-air/commit/7cbd064acaba22255cae2d376fcd213bfc267743
Excerpts are now not displaying with the air theme. Is there anyway to get them to display again?
Hi Jacob - can you confirm what version of Core you have? This change from two days ago made some improvements to the API which discourse-air now depends on.
@david - great thanks for the quick reply, here you go, this is our version:
Not sure if this is helpful but it appears to still show for pinned topics, as you can see here:
Okay intersting, I can see here on meta.discourse.com that excerpts are still showing when I use the air theme…
If you visit the “Update” tab in your dashboard and upgrade to the latest version of core, then I think the issue should be resolved.
That said, ideally the theme shouldn’t be dependent on such a recent change to core, so I will look at adding some backwards-compatibility on the theme side :eyes:
@david that did it, updating to the latest version and the excerpts are back!
Great! I’ve also prepared a tweak for the theme so that this problem shouldn’t affect anyone else.
Thanks for reporting the issue!
