iOS에서 핀치 줌 시 크래시 발생 (Graceful 테마)
iOS 18.2 pinch zooming mostly crashes. Cannot zoom to images but also anything in a topic.
UPDATE: It seems to happen when you pinch zoom and then you “rough” swipe with one finger (e.g. to move all the way down) when zoomed in. Or zoom out. You must zoom into a content. When you zoom e.g. on buttons, it might not crash.
4개의 좋아요
Crashes like this are likely browser bugs, that said I have alerted the team in case they have any ideas.
2개의 좋아요
I haven’t been able to reproduce this on iOS 18.2.1.
Is anyone else seeing the same problem?
1개의 좋아요
OK, I upgraded to 18.2.1 and after few tests I cannot reproduce again.
2개의 좋아요
It happened again (iOS 18.2.1). If I zoom in and then I zoom out but much more than 1:1, I can reproduce the crash.
4개의 좋아요
Thanks @tvavrda - a few of us on the team have been able to reproduce the same issue, and are looking into it :eyes:
3개의 좋아요
It is certainly a browser bug, but @pmusaraj just merged a fix that appears to fix it in our testing.
https://github.com/discourse/discourse/commit/73b28815e301e26c7f4a0a449e205487c4e9d6bc
Can you confirm all is working after you update?
3개의 좋아요
It works now on the default theme. But I have GitHub - discourse/graceful · GitHub installed and there it still crashes :man_shrugging:
1개의 좋아요
@pmusaraj / @awesomerobot I wonder if graceful has some elements with -1 z-index?
1개의 좋아요
It does but removing it did not help. Or maybe I did something wrong.
2개의 좋아요
We will have a look will keep the bug open for now.
(I tagged it for clarity on what the bug has evolved to)
3개의 좋아요
This should fix it: FIX: Prevent bug with pinch zooming in Safari iOS by pmusaraj · Pull Request #40 · discourse/graceful · GitHub
I’m going to file this upstream tomorrow (or see if somebody else filed it), this very much feels like a recent regression in Safari on iOS, this code has been in the Graceful theme for a long time.
6개의 좋아요
The fix above is now merged, looks good here on meta, hope it’s the same on your instance @tvavrda, thanks for the report!
I tried to repro this on a simple codepen so I could report upstream, but I can’t repro. Something else on our app might contribute to the problem, trouble is, not sure how to track down what else is a contributing factor.
3개의 좋아요
Seems good so far! I had a customized theme so I just reproduced your modifications and it looks good. I can finally look at images from my phone! Thanks for the support :heart:
4개의 좋아요
Pinch zooming stopped working whatsoever to me now :sad_but_relieved_face:
1개의 좋아요
Yes, confirmed, must be a different regression. Looking into it!
1개의 좋아요
@tvavrda are you testing on Safari for iOS? Here on meta, I can pinch zoom in Safari, but I can’t in DiscourseHub (our mobile app).
I am on iOS 18.2.0 (upgrading to 18.2.1 and testing again).
You are right. It works in the browser. I use PWA. There it doesn’t.
2개의 좋아요
Sorry about that! I hadn’t specifically tested DiscourseHub/PWA with one of my recent changes. This commit should fix up pinch-zooming there.
5개의 좋아요
Seems to work again on PWA. Thanks!
3개의 좋아요
