게시 가능한 카테고리 제한을 우회하는 방법
I recently noticed this glitch where if you go to a category that you cannot post in (such as a rules category) and you quote something, it sets the category to that category that you quoted from. Here is an example from the Stateview Forums: where I quoted one random word:
This may only be on that site, but I just want to make sure that this isn’t a discourse wide issue, as this could be a problem.
Also, I haven’t actually tried posting it, I don’t want to get in trouble there.
3개의 좋아요
I can reproduce this issue on a test site, so it’s a Discourse-wide issue, but when this happens you’re not allowed to post the topic unless you change the category to one you have permission to create in.
Ideally we should update this to fallback to the default category or no category selected.
Thanks for reporting it!
4개의 좋아요
Oh, ok, but it should still be fixed so that it doesn’t show the current category, as it would cause confusion, and no problem!
2개의 좋아요
I think this was already reported in Quoting a closed topic prefills category in composer that should be off-limits
4개의 좋아요
Let’s keep it in the original topic (thanks for the report!)
