사용자 검색 시 항상 본인이 검색 결과에 나옴
When using More → User, when a filtered match is found, the list always includes the user executing the search. When there is no match, the list is empty i.e. zero entries for no match, 2 or more entries for a match. Tested using multiple user accounts - same result.
I upgraded this weekend. Not sure if a new issue related to that or if a pre-existing condition. Previous upgrade was around Christmas and certainly didn’t notice this misbehaviour, so I think it is recent.
Confirmed same here on meta…
1개의 좋아요
I think it has always been that way
3개의 좋아요
I appreciate the pointer to the related topic. However, the reply in that topic says “I think that’s by design”. It’s a thought, but not an explanation. To me, the behaviour I reported is counter-intuitive. If it’s not a bug, I’d like to understand why the current behaviour is the desired/designed behaviour. I can’t think of a good reason myself.
2개의 좋아요
The user directory is also an activity leaderboard, so always showing your own account allows you to easily compare statistics.
I believe this is also why we show the current user at the top of the unfiltered list a second time, in addition to the natural placement further down the list, so you don’t have to endlessly scroll or filter to compare your own statistics.
4개의 좋아요
Thanks. Something like that, I can get my head around. And that logic aligns with highlighting self with colour in the filtered list. I just hope I can remember when my users ask.
2개의 좋아요
It’s a little convoluted, but if you wanted to add some CSS (admin > customize > themes) to disable this behavior in filtered results… it’s possible:
.directory:has(.filter-name:not(:placeholder-shown)) .me {
  display: none;
this essentially says “if the directory filter is not showing the placeholder (i.e., a term has been entered) then don’t display my account in the results”
but note this would also remove yourself from matching filters, so it’s an imperfect workaround
4개의 좋아요
