카테고리 배너를 활성화하면 카테고리 아이콘이 중복으로 표시됩니다
This is a fresh install of category-banners, on a category with an icon. For some reason, it duplicates the icon. Is there a way to default to the original category icon
being hidden when the category banners theme component is on?
I think you can use the css solution that was shared in Default category heading not hidden when category banner is used
Didn’t even find that bug…sorry!
It still doesn’t align the text to the center of the icon, which I guess is another issue also mentioned in that topic with no resolution.
@Moin any chance you know that one?
I don’t know very well the grid layout. That said…
If you don’t display the category descriptions at all, you can replace
.category-title-contents {
    display: grid;
    grid-template-areas:
        "logo title"
        "logo description";
    grid-template-columns: auto 1fr;
with
    display: grid;
        "logo title";
The original layout splits the container into 4 cells, which misaligns the title:
Removing the “logo description” area makes it 2 cells:
Which allows you to vertically align the title by replacing:
.category-title-contents .category-title {
    grid-area: title;
    align-self: end;
with
    grid-area: title;
    align-self: center;
