숨겨진 게시물의 게시물 메뉴에서 북마크 숨기기
Bookmarking does not work on posts that have been hidden because of flags. I think the experience would improve if the bookmark button were hidden from the post menu in this case, similar to how the ‘like’ button is.
8개의 좋아요
//*[@id="ember38"]에서 선택하면:
<button class="btn no-text btn-icon fk-d-menu__trigger bookmark-menu-trigger post-action-menu__bookmark btn-flat bookmark widget-button bookmark-menu__trigger btn-icon no-text" aria-expanded="false" title="bookmark this post" data-identifier="bookmark-menu" data-trigger="" type="button" id="ember38">
<svg class="fa d-icon d-icon-bookmark svg-icon svg-string" aria-hidden="true" xmlns="http://www.w3.org/2000/svg"><use href="#bookmark"></use></svg>      <span aria-hidden="true">
        </span>
    </button>
…다음과 같은 내용을 확인합니다:
오류가 발생했습니다: 요청한 리소스를 볼 권한이 없습니다.
ECMAScript 콘솔은 다음을 반환합니다:
12:24:12.798 XHRPOST
https://discussion.fedoraproject.org/bookmarks.json
[HTTP/2 403  160ms]
12:24:04.683 Uncaught (in promise) TypeError: can't access property "saveData", e is undefined
    create bookmark-api.js:20
    create post-bookmark-manager.js:36
    onBookmark bookmark-menu.gjs:124
    onShowMenu bookmark-menu.gjs:147
    show float-kit-instance.js:28
    show d-menu-instance.js:101
    onTrigger d-menu-instance.js:136
    onClick d-menu-instance.js:120
bookmark-api.js:20:7
대신, 숨겨져 있거나 (아마도 더 좋겠지만) 비활성화되어 있어야 합니다.
