עדכוני Discourse - Microsoft Defender מדווח על זיהוי של תוכנת זדון Wacatac
סיכום מבוסס בינה מלאכותית
A self-hosted Discourse user, MiaZ, reported that Microsoft Defender flagged files in their Docker container as Wacatac malware after updating to Discourse v3.4.0.beta3. The flagged files were located in pnpm/store/v3/files and were identified by david as cached binaries of legitimate npm packages — specifically lefthook and esbuild. Verification via MD5 hashes confirmed the files matched official npm releases, indicating a false positive. david advised against removing the files, as they are essential for Discourse operation, and noted that similar false positives against npm packages are not uncommon, citing a prior example with esbuild. MiaZ thanked the team and contacted Microsoft Defender support. Their response included options like marking files as clean or suppressing alerts — which MiaZ declined to avoid missing real threats — and MiaZ submitted a feedback request to improve Defender’s scanning algorithm: Azure Feedback Link.
Hi,
We have a self-hosted instance of Discourse on a virtual machine and after applying most recent Discourse updates v3.4.0.beta3 +431we have received alert from Microsoft Defender about Wacatac malware:
We have removed the file, restarted the virtual machine and now we´re waiting for another scan to run. This has already happened on December 2024 when we were pulling most recent Discourse updates.
It seems that Wacatac is somehow coming via Discourse updates or it might also be a false positive…
Is anyone else facing this issue?
Please can you let us know the full path of the file it detected?
var/lib/docker/overlay2/d5d34d6148be507180106dc3b39b8b3d266b5e221fd5df48ce023df57186d4ef/diff/home/discourse/.local/share/pnpm/store/v3/files
(we always find it here)
.../pnpm/store/v3/files is a directory. Do you have the name of the specific file as well?
/var/lib/docker/overlay2/93cd7bbb9de06047b645e0b7e3fd788546257d0b2d980e21df3cb0c5c802e80f/diff/home/discourse/.local/share/pnpm/store/v3/files/1e/a9a94e4c7f5e4b8e407d5bbbec51f6167dd6470f9e9c6b41b3f99facbe9749c0c1a60f6cac13a74d7e09482601470bea436265eccd6091e0767ff9b05e66eb-exec
And for the one from December 2024:
/var/lib/docker/overlay2/d5d34d6148be507180106dc3b39b8b3d266b5e221fd5df48ce023df57186d4ef/diff/home/discourse/.local/share/pnpm/store/v3/files/23/f5520e308f56ab79324ef0ea1249acf7aa09f192d1b5e5599b3b284e46f1e6c0d6d58707b63a9c965399930b6148639ef2bd6d1d4d55343448ba42b4535440-exec
Thanks for the extra info!
@mwaniki helped me to do some checks on this. The first file you shared is a cache of the lefthook binary:
$ md5sum /home/discourse/.local/share/pnpm/store/v3/files/1e/a9a94e4c7f5e4b8e407d5bbbec51f6167dd6470f9e9c6b41b3f99facbe9749c0c1a60f6cac13a74d7e09482601470bea436265eccd6091e0767ff9b05e66eb-exec
8bfaa34901d5a7b34090b3a862793f90  /home/discourse/.local/share/pnpm/store/v3/files/1e/a9a94e4c7f5e4b8e407d5bbbec51f6167dd6470f9e9c6b41b3f99facbe9749c0c1a60f6cac13a74d7e09482601470bea436265eccd6091e0767ff9b05e66eb-exec
$ find /var/www/discourse/node_modules/ -type f -exec md5sum {} + | grep '^8bfaa34901d5a7b34090b3a862793f90'
8bfaa34901d5a7b34090b3a862793f90  node_modules/.pnpm/lefthook-linux-x64@1.10.8/node_modules/lefthook-linux-x64/bin/lefthook
The second is esbuild:
$ md5sum /home/discourse/.local/share/pnpm/store/v3/files/23/f5520e308f56ab79324ef0ea1249acf7aa09f192d1b5e5599b3b284e46f1e6c0d6d58707b63a9c965399930b6148639ef2bd6d1d4d55343448ba42b4535440-exec
25b47c7a561185d07c8c3d98ade527af  /home/discourse/.local/share/pnpm/store/v3/files/23/f5520e308f56ab79324ef0ea1249acf7aa09f192d1b5e5599b3b284e46f1e6c0d6d58707b63a9c965399930b6148639ef2bd6d1d4d55343448ba42b4535440-exec
$ find node_modules/ -type f -exec md5sum {} + | grep '^25b47c7a561185d07c8c3d98ade527af'
25b47c7a561185d07c8c3d98ade527af  node_modules/.pnpm/@esbuild+linux-x64@0.24.2/node_modules/@esbuild/linux-x64/bin/esbuild
25b47c7a561185d07c8c3d98ade527af  node_modules/.pnpm/esbuild@0.24.2/node_modules/esbuild/bin/esbuild
Those md5 hashes correspond to the published versions on npm, so we can be confident that they haven’t been tampered with between the registry and your installation:
$ curl -s https://registry.npmjs.org/@esbuild/linux-x64/-/linux-x64-0.24.2.tgz | tar -Oxzf - package/bin/esbuild | md5sum
25b47c7a561185d07c8c3d98ade527af  -
$ curl -s https://registry.npmjs.org/lefthook-linux-x64/-/lefthook-linux-x64-1.10.8.tgz | tar -Oxzf - package/bin/lefthook | md5sum
8bfaa34901d5a7b34090b3a862793f90  -
So I think this has to be a false positive from Microsoft Defender. Removing esbuild from your Discourse installation will cause issues, so I’d recommend against that.
Searching online, it seems like Microsoft Defender falsely alerting against npm packages is fairly common. Here’s an example of a false detection of esbuild in the past.
Thanks so much @david and @mwaniki! :clinking_glasses:
We will now try to reach out to Microsoft Defender´s support team and share their feedback if/when we get one.
As promised, this is the current feedback from Microsoft support:
  • Mark files as clean in Microsoft Defender for Cloud so to resolve alert → we did this, but we don´t see it as contributing to issue resolution since each time different file is falsely reported
  • Suppress entire alert in Microsoft Defender for Cloud → we didn´t want to do this so not to miss out on possible actual threats in the future
  • Submit idea for improvement of Defender scanning algorithm and/or internal database → we did this, waiting for feedback: Community
