구독 목록이 표시되지 않습니다
Hi
All the settings seems to be fine, but i can’t manage to display the subscriptions button here
s/subscriptions
Any ideas? Thanks
I also tried on your site, a standard install with the Subscription plugin added today.
There could be some new bug in the plugin, but I haven’t seen any other complaints, and the last update was 2 weeks ago.
Are you sure that your Stripe account is fully activated? Have you been using it for something else?
Yes. It seems a bug or something weird because the stripe accounts seems to be syncing well products with the admin page.
So are you using a pricing table then?
What is being displayed on that page?
No, im not using a price table. I created a product that’s synced with stripe
Okay cool. So subscriptions will load at just /s then.
The “Subscribe” button will only show up for signed in users.
When i try to enter /s it redirect me to the /s/subscriptions
That should only happen if “Discourse subscriptions pricing table enabled” is checked. Can you double check that it isn’t checked?
Thanks! That was the issue.
