왜 내 아바타가 궤도 기포와 함께 깜빡이고 있나요? 사라지지 않아요. 모든 알림을 닫아 봤는데도 계속 남아 있어서 미치겠어요. 이걸 제거해 주세요!
의미 있는 채팅 채널에 접근할 수 있는 것 같지도 않아요.
The orbitals went away. Can someone please explain?
That’s probably related to this: Discourse Rewind 2024
It happened with Discourse Rewind 2024. It should disappear once you visited it.
Yeah was too bad it disappeared. Kind of liked the visual effect over the simple dot/icon showing a notification. ![]()
It shows when you have not visited the Rewind page. I struggled to get rid of it as well, and once I did visit “Rewind” (which I love BTW) I can’t find a way to get the link or the effect back.
Yeah for some reason you have to refresh the page to get rid of it. @jordan.vidrine built it so he can probably comment more.
#customization:theme-component을 통해 효과를 대체 알림으로 추가할 수 있으면 좋겠어요. ![]()
This animation is very troubling. Thank you all who responded. Indeed @HAWK, this is when I opened an internal link into a new tab that I noticed the animation had disappeared. I reloaded the original tab and it went away. It’s not so good for epilepsy and other troubles related to stress.
WRT the Discourse Rewind, it looks nice and is quite funny, but somehow found that ai is an interesting tag for me: maybe because I tried to mute all AI things? – I think I muted that tag anyway.
Yes, the hovering dots were mostly just a visual attractor for rewind. It was there to get people to click on their avatar, open the notification panel, and see that rewind was available to view ![]()
Once you click through to the rewind page, that animation will no longer load, but it does require a refresh. Since this was just an experimental plugin, we didn’t go too deep in storing this data on the user in the DB. We just opted for local storage.
So if you really want to see it appear again, you can remove discourse_rewind_2024_dismissed from your localStorage for meta.discourse.org
I just logged in again and got the Rewind again. Didn’t change anything on the localStorage. Probably an expired session cookie? Probably should be a flag in the DB…
This was just a quick experimental possibly throw-away project (though I hope we continue to do it). So yes, probably should be in the DB, but it is not.
If you log out and back in, it also triggers the Rewind to happen. It’s something we will take a look at.
Something different and fun, why not?!
네! 정말 좋겠습니다!
