התאמת גודל היומן במחשבDesk
I was inspecting inside the html class containing desktop-view not-mobile-device, to reduce the calendar size on desktop, and have found where the CSS might need to be changed to achieve this task.
the class fc-month view appears to be the calendar widget we’re interested in, and i was able to resize it locally and relatively, using CSS, through the fc-view-container class. However, i was only able to scale the width, not the height or overall size.
Has anyone else encountered this issue, when trying to modify locally?
You should be able to change the height using the .calendar.fc element.
Ah, but unfortunately you’ve pictured the per topic calendar, and not the category one
Same element is shown on the category view. You may need a bit more CSS though:
#main-outlet .calendar.fc.fc-unthemed {
  height: 200px;
  overflow-y: scroll;
