파이어베이스를 호스팅 옵션으로 사용할 수 있을까요? 그리고 AWS와 Google Cloud 중 가장 좋은 호스팅 옵션은 무엇인가요?
Thank for replying but the guide doesn’t tell anything about firebase as a options and also not included the google cloud. I understand that these may not be the best options but I want to know that can we use them or not.
Our official install guide lists the requirements to host Discourse. If Firebase supports the listed requirements and allows SSH access, it can run Discourse:
- modern single core CPU, dual core recommended
- 1 GB RAM minimum
- 64 bit Linux compatible with Docker
- 10 GB disk space minimum
I added this section:
IIRC Firebase hosting is serverless, so it won’t work with Discourse.
