רכיבים מותאמים אישית -- הוסף כפתור או טקסט בכל יציאת תוסף
Install this theme component
Add a link button or arbitrary text at any plugin outlet. (Ignore the watermarks in the images–I took these screenshots on a staging/test site.)
To see where the plugin outlets are, use Introducing Discourse developer toolbar to find them. If you don’t know what a plugin outlet is, you can have a look at Using Plugin Outlet Connectors from a Theme or Plugin, but this component allows you, with some restrictions, stick text in any plugin outlet without doing programming or really understanding what a plugin outlet is.
I started developing this plugin for someone who wanted to display a “click this button to subscribe so that you can send PMs” button on user profiles and user cards. They wanted the button to display if the user couldn’t send PMs. Because I’m not always as clever as I’d like to think, I wrote the component using groups to determine whether the button was displayed. One problem with this approach was that staff members weren’t in the subscriber group, so they’d get the “you gotta subscribe” button even though they could send PMs. Also, the group was hidden, so it was impossible to use it in a theme component anyway. I re-wrote that theme component to use currentUser.can_send_private_messages to determine whether to display the button.
Who is this for?
If you want to put a button with a link in it, or some arbitrary text that is displayed or hidden for certain groups, this will let you insert them at any plugin outlet. You want to add a “You outa subscribe” link button between every message except for those who aren’t members? This will do it. You want to stick some arbitrary HTML at a plugin outlet, just to see what it’ll look like? This will do that.
How it helps developers
This theme has some simple examples of how to:
but if you’re trying to do it inside of a <template> inside of a .gjs file, it works a little differently (like {{htmlSafe component.text}})
17 לייקים
Space makes the text not bold.
Great component!
5 לייקים
Would it be possible to add placeholders to the Button URLs, e.g. for the URL to contain the topic ID in which the user is located?
I’m not quite sure. If you’ve got a budget, I’ll take a look.
What would your button do if it had the topic id?
If you figure it out and want to make a PR, I’ll probably accept it.
I’m pretty sure that the answer is no, but that you could use the workaround described here
2 לייקים
Hi @pfaffman
We want to add such a set of buttons to every topic for members in our business account user group.
The button would then trigger creating a new PM which then includes the current URL the user is on
That way our business customers can send us request to pin, highlight or “sponsor” speficic topics
לייק 1
As you know, you can create a URL that will open a new topic composer. You could make that be the link added by the theme component.
I don’t think that it’s possible to do that without adding code to the theme component (but maybe it is?). Maybe someone has an idea about that and will offer that solution here (or on the other topic). If not, you can contact me or post in Marketplace with the description of what you need and a budget.
3 לייקים
The demo text block is not aligned with the demo button and the rest. I use extra-nav-item in block outlet.
I think you need to add the class of those other buttons to the one that you’ve added.
What do you mean?I tried using the same class as the demo button.
yup. Since that’s text and not a button, you’ll need to add some CSS to make it look like the other things that are buttons there.
The theme component put the text where you want it, but it’s not designed to style it like you want it.
Adding this to your CSS in some theme should work.
.custom-component.btn-custom {
  display: inline-flex;
  align-self: center;
Hi, it’s not working. Also even the Text Block Groups is set to Everyone the text block is not showing for guests.
You need to make the class of the text block in the theme settings match the class in the css I showed.
Also, you should change the setting to have it HIDE the matched groups rather than show for the matched groups
If you need more help and have a budget, my email address is in my user card.
Thanks! I got the CSS to work!
Awesome! Glad it’s working! That css stuff is still tricky for me.
