DeepSeek-R1 randomly producing "Job exception: undefined method `finish' for nil" error
Users are reporting a sporadic error—"Job exception: undefined method finish' for nil"—when using the DeepSeek-R1 model via AI Bot, particularly during longer response generation. [MachineScholar](/t/-/349703/1) notes the issue aligns with OpenAI-style setup per [DeepSeek’s documentation](https://api-docs.deepseek.com), and shares a backtrace pointing to decode_chunk_finish` in the plugin code. sam acknowledges the bug and plans a partial fix, noting the deeper issue is likely insufficient timeout settings—currently hardcoded to 60 seconds—while reasoning models may require up to 5 minutes. sam confirms they’ve already increased the timeout to 6 minutes. MachineScholar reports the model now works well via HuggingFace Inference API, though intermittent 502/504 errors occur, which they attribute to HuggingFace’s infrastructure under load, reminding users that free endpoints are currently very busy.
Whenever interacting with this particular model via AI Bot, it randomly produces this error. Sometimes it happens and sometimes not but I can’t tell exactly what is causing it, although I think it happens more often when it’s “thinking” for a longer period of time.
It’s set up using the OpenAI settings as described here, which is in line with DeepSeek’s documentation:
Backtrace
Message (7 copies reported)
Backtrace
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/open_ai.rb:126:in `decode_chunk_finish'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:209:in `block (2 levels) in perform_completion!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:2433:in `block in transport_request'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:320:in `reading_body'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:2430:in `transport_request'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:2384:in `request'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/net_patches.rb:19:in `block in request_with_mini_profiler'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:50:in `step'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/net_patches.rb:18:in `request_with_mini_profiler'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:117:in `block in perform_completion!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1632:in `start'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1070:in `start'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:100:in `perform_completion!'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/open_ai.rb:40:in `perform_completion!'
/var/www/discourse/plugins/discourse-ai/lib/completions/llm.rb:279:in `generate'
/var/www/discourse/plugins/discourse-ai/lib/ai_bot/bot.rb:115:in `reply'
/var/www/discourse/plugins/discourse-ai/lib/ai_bot/playground.rb:477:in `reply_to'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/create_ai_reply.rb:18:in `execute'
/var/www/discourse/app/jobs/base.rb:316:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:303:in `block in perform'
/var/www/discourse/app/jobs/base.rb:299:in `each'
/var/www/discourse/app/jobs/base.rb:299:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:202:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:132:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:182:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:169:in `block in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:113:in `local'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:263:in `stats'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:13:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:80:in `global'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:124:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:39:in `prepare'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:123:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:168:in `process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:78:in `process_one'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:68:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:8:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:17:in `block in safe_thread'
This problem seems related to this issue, but I’m not certain that I really understand this error to be honest.
I will put a quick bug fix into my branch, but it will probably only land some time next week
I suspect it is only a half fix, the bigger problem is that reasoning models may need ridiculous timeouts (like 5 minute timeouts) and we are now hardcoded to 60 seconds.
FWIW I bumped up our timeout to 6 minutes today given all the reasoning models
I can confirm it now works well. Currently running DeepSeek-R1 using the HuggingFace Inference API. There are intermittent 502 and 504 errors, but that’s the fault of HF I believe. Users should expect all free endpoints to be extremely busy for now lol.
This topic was automatically closed after 14 hours. New replies are no longer allowed.
