Categorieën worden niet omgezet zoals tags, wat zorgt voor overloop op mobiel
Users have reported that long category names cause layout issues on mobile devices. huynhthai824 initially noted that category names overflow the filter container and topic list, unlike tags which wrap. awesomerobot mentioned adjustments were made to address this. However, unknown_error pointed out additional issues with category names in ‘Suggested’ posts, including overflow when the viewport size is decreased and lack of ellipsification. Moin confirmed ongoing problems with long category names in topic lists and chat, noting truncation and misalignment issues.
Hi everyone, I’ve noticed that tag names in the filter dropdown can wrap to the next line if they’re too long, which is great for mobile responsiveness. However, category names don’t seem to have the same behavior. When a category name is too long, it overflows the filter container, breaking the layout on mobile devices.
Here are two screenshots to illustrate the issue:
Long category names also overflow on the topic list. Because it’s very minor and slightly related, I’ll leave this here instead of creating a new topic (feel free to move it if necessary):
Category names should ideally be short and it was the first time I saw this behavior.
I’ve added some adjustments to avoid this
https://github.com/discourse/discourse/pull/31335
let us know if you encounter any more problems with long category names!
@awesomerobot,
This also seems to be an issue with category names in the “Suggested” posts at the bottom of a thread.
There seems to be two separate but related problems:
  1. If the viewport size is decreased after the initial pageload, the table doesn’t shrink down correctly:
This causes table.topic-list to overflow the width of #main-outlet-wrapper
  1. Separately, h3.more-topics__browse-more a.badge-category__wrapper doesn’t ellipsify (regardless of whether the page was mobile-sized at pageload or shrunken down), which also causes the page to be too wide. It can be forced to with a max-width: 80vw or thereabouts, but that might have unintended consequences on wider monitors.
I have the impression that there is still a problem with long category names in topic lists.
This is what I see on https://forums.cfl.ca/filter?q=category%3Acanadian-grassroots-football%20. The category name is truncated, but the date is still too far on the right.
And it’s also a problem to mention categories with long names in chat
