There’s is a task we do today that I’ve been able to make pretty good progress in automating using n8n, but I’m wondering if it’s possible with Discourse natively.
We have a draft category where product marketing managers draft product announcements to be sent out about their products. When they create that draft, we look at the product name, the version, if it’s a major/minor/patch release. We also take the body of their announcement content and summarize it with a LLM for a 4-7 word description of the content.
We then use that to create the announcement banner in Adobe, like so:
Netwrix is pleased to announce the general availability of Netwrix PolicyPak build number 25.2. With this release, you will be able to benefit from the following: PolicyPak - General End-of-Life for 32-bit PolicyPak This is a reminder that...
Reading time: 3 mins 🕑
Likes: 16 ❤
I feel as though this could be done by an LLM and some traditional logic:
The background is just one hue per announcement type and there are four variations of each color—we just randomly select one.
The product name and version are entered into the boxes at the top
The description in the body middle-center there
We use https://storyset.com/ to whip up a quick illustration to put on the right.
I feel I have a good approach to doing this with n8n, but wonder if it could be done natively with Discourse AI and other tools?
sam
(Sam Saffron)
1 mei 2025 om 01:46
3
The Designer persona using the excellent new GPT Image 1 model is capable of doing stuff like this:
AI Conversation with Us.anthropic.claude-3-7-sonnet-20250219-v1:0
sam : Help me make an announcement banner for PolicyPak 25.3: Client-Side Extension Enhancements. it should look modern and and include a banner. A bit about PolicyPak: Netwrix PolicyPak
netwrix.com/endpoint
CUSTOMER FEEDBACK
“Netwrix PolicyPak makes it much easier to comply with federal security mandates. In fact, in some cases, we would simply have no way
to implement the mandated settings without…
sonnet-3-7-thinking : [A modern, professional announcement banner for PolicyPak 25.3 featuring 'Client-Side Extension Enhancements' as the focus. The banner should have a clean, corporate tech aesthetic with a blue and white color scheme. Include the Netwrix logo and PolicyPak branding. The design should visualize endpoint management with subtle icons representing devices (laptops, desktops, mobile) connected acro…
sam : [This image announces PolicyPak version 25.3, highlighting "Client-Side Extension Enhancements" with an illustration of a person on a laptop next to a password graphic. (Captioned by AI)]
I was thinking more about this type of style.
try another prompt that emulates it a bit better.
Read full transcript
I think you could wire something up using custom presona and using the right tools to achieve a lot of this, for sure.
sam
(Sam Saffron)
1 mei 2025 om 03:23
4
Note for custom tool usage, as long as there are proper REST APIs you can integrate easily, for example this is how I integrate with flux image generation:
const apiKey = "password";
const model = "black-forest-labs/FLUX.1.1-pro";
let prompt;
function invoke(params) {
let seed = parseInt(params.seed);
if (!(seed > 0)) {
seed = Math.floor(Math.random() * 1000000) + 1;
let height = parseInt(params.height);
if (!height || height < 256 || height > 1440) {
height = 768;
let width = parseInt(params.width);
if (!width || width < 256 || width > 1440) {
width = 1024;
width = width - (width % 32);
height = height - (height %32);
prompt = params.prompt;
const negative_prompt = params.negative_prompt || "";
const body = {
model: model,
prompt: prompt,
width: width,
height: height,
steps: 10,
n: 1,
seed: seed,
negative_prompt: negative_prompt,
response_format: "b64_json",
const result = http.post("https://api.together.xyz/v1/images/generations", {
headers: {
"Authorization": `Bearer ${apiKey}`,
"Content-Type": "application/json",
body: JSON.stringify(body),
if (result.status !== 200) {
return { error: true, body: result.body };
const base64Image = JSON.parse(result.body).data[0].b64_json;
const image = upload.create("generated_image.png", base64Image);
const raw = `
if (!params.show_to_user === false) {
chain.setCustomRaw(raw);
return { result: "Image generated successfully", prompt: prompt, url: image.url, seed: seed, negative_prompt: negative_prompt };
function details() {
return prompt;
You can see the HTTP post and the parsing of the base 64 image in the sample.
If given a post body, does the burden for turning content from that body into valid parameters fall on Discourse AI to read the content and then create the request object? Or should the raw content be passed onto the tool and the burden for an LLM parsing that for the necessary data to construct a proper input for its API call exist there?
sam
(Sam Saffron)
1 mei 2025 om 04:04
6
Yes in that case the tool has an api already for reading posts so you can just pass an id in
Would you be able to point me to the docs for this by chance?
sam
(Sam Saffron)
12 mei 2025 om 01:35
10
Sorry for the delayed reply here, it is tricky, our documentation is evolving and the API surface is growing weekly.
This kind of technique provides some accurate up to date mileage, but I think we need to wait a bit for all the API to stablize prior to setting stuff in stone:
AI Conversation with Gemini-2.5-pro:
sam: I need you to read discourse-ai/lib/personas/tool_runner.rb at main · discourse/discourse-ai · GitHu… gemini-2.5-pro: Okay, I can help with that!
First, I’ll need to fetch the content of the tool_runner.rb...
