I keep getting errors when updating
A user is experiencing persistent errors when trying to update Discourse via the browser, receiving a Sorry, there was an error updating Discourse message. The issue appears to be related to insufficient memory and disk space, particularly on a DigitalOcean droplet with 1GB RAM and 25GB disk. The community suggests increasing the swap file size to 4GB, as the update process requires more memory than available. The user successfully resolves the issue after increasing the swap file, but remains concerned about disk space usage, especially since Discourse consumes around 18GB of storage. Discussions include advice on using ./launcher cleanup, managing Docker storage, and considerations for upgrading to higher-tier plans. The user plans to upgrade to a 2GB RAM, 50GB disk plan when the community grows, while acknowledging the complexity of DigitalOcean’s pricing and CPU type limitations. The thread also touches on the importance of backups and the option to use Hetzner as a more cost-effective alternative.
No matter how many times I try to update, I always get Sorry, there was an error updating Discourse. Please check the logs below. when updating via the browser. I always have to rely on Terminal and that isn’t good, because then I will always have to have my forum down for like 30 minutes.
If anyone can help me here, that would be appreciated.
Errors:
Summary
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 603
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Waiting for Unicorn to reload.........
Waiting for Unicorn to reload..........
Waiting for Unicorn to reload...........
Waiting for Unicorn to reload............
Waiting for Unicorn to reload.............
Waiting for Unicorn to reload..............
Waiting for Unicorn to reload...............
Waiting for Unicorn to reload................
Waiting for Unicorn to reload.................
Waiting for Unicorn to reload..................
Waiting for Unicorn to reload...................
Waiting for Unicorn to reload....................
Waiting for Unicorn to reload.....................
Waiting for Unicorn to reload......................
Waiting for Unicorn to reload.......................
Waiting for Unicorn to reload........................
Waiting for Unicorn to reload.........................
Waiting for Unicorn to reload..........................
Waiting for Unicorn to reload...........................
Waiting for Unicorn to reload............................
Waiting for Unicorn to reload.............................
Waiting for Unicorn to reload..............................
Waiting for Unicorn to reload...............................
$ cd /var/www/discourse && git reset --hard HEAD@{upstream}
HEAD is now at fe1b1edba FIX: removes + from RTE toggle tooltip (#33542)
$ bundle install --retry 3 --jobs 4
Bundle complete! 143 Gemfile dependencies, 190 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
3 installed gems you directly depend on are looking for funding.
  Run `bundle fund` for details
$ if [ -f yarn.lock ]; then yarn install; else CI=1 pnpm install; fi
Scope: all 16 workspace projects
Lockfile is up to date, resolution step is skipped
Already up to date
Done in 9.1s using pnpm v9.15.6
$ LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all
discourse-adplugin is already at latest compatible version
discourse-categories-suppressed is already at latest compatible version
discourse-doc-categories is already at latest compatible version
Invalid version list in /var/www/discourse/plugins/discourse-landing-pages
discourse-landing-pages is already at latest compatible version
discourse-solved is already at latest compatible version
docker_manager is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
Multisite migrator is running using 1 threads
Migrating default
Seeding default
*** Bundling assets. This will take a while ***
$ bundle exec rake themes:update assets:precompile
Updating themes with concurrency: 10
[db:default] 'New Topic Header Button' -  checking...
[db:default] 'New Topic Header Button' -  up to date
[db:default] 'Category Banners' -  checking...
[db:default] 'Category Banners' -  up to date
[db:default] 'Clickable Topic' -  checking...
[db:default] 'Clickable Topic' -  up to date
[db:default] 'Tag Banners' -  checking...
[db:default] 'Tag Banners' -  up to date
[db:default] 'Breadcrumb Links' -  checking...
[db:default] 'Breadcrumb Links' -  up to date
[db:default] 'Welcome Link Banner' -  checking...
[db:default] 'Welcome Link Banner' -  up to date
[db:default] 'Tag Icons' -  checking...
[db:default] 'Tag Icons' -  up to date
[db:default] 'Social Share' -  checking...
[db:default] 'Social Share' -  up to date
[db:default] 'Navigation Menu Display Control' -  checking...
[db:default] 'Navigation Menu Display Control' -  up to date
[db:default] 'DiscoTOC' -  checking...
Node.js heap_size_limit is less than 2048MB. Setting --max-old-space-size=2048 and CHEAP_SOURCE_MAPS=1
Existing build is not reusable.
- Existing: {"ember_env"=>"production", "core_tree_hash"=>"c71c1ad482ff7f24c3ad3a76d5a521861f29e1fb"}
- Current: {"ember_env"=>"production", "core_tree_hash"=>"d026d5621e9421eaf67123aab7361a44f0fa9c31"}
Running full core build...
Building
Environment: production
The setting 'staticAddonTrees' will default to true in the next version of Embroider and can't be turned off. To prepare for this you should set 'staticAddonTrees: true' in your Embroider config.
The setting 'staticAddonTestSupportTrees' will default to true in the next version of Embroider and can't be turned off. To prepare for this you should set 'staticAddonTestSupportTrees: true' in your Embroider config.
building...
...[ConfigLoader]
...[Babel: @embroider/macros > applyPatches]
...[Babel: pretty-text > applyPatches]
...[Babel: @ember/legacy-built-in-components > applyPatches]
...[Babel: ember-source > applyPatches]
[BABEL] Note: The code generator has deoptimised the styling of /var/www/discourse/app/assets/javascripts/discourse/ember/ember-template-compiler.js as it exceeds the max of 500KB.
[BABEL] Note: The code generator has deoptimised the styling of /var/www/discourse/app/assets/javascripts/discourse/ember/ember.js as it exceeds the max of 500KB.
...[Babel: @glimmer/component > applyPatches]
...[Babel: @ember/render-modifiers > applyPatches]
...[Babel: dialog-holder > applyPatches]
...[Babel: ember-this-fallback > applyPatches]
...[Babel: ember-buffered-proxy > applyPatches]
...[Babel: ember-cache-primitive-polyfill > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
undefined
 ERR_PNPM_RECURSIVE_EXEC_FIRST_FAIL  Command was killed with SIGKILL (Forced termination): ember build -prod
/var/www/discourse/script/assemble_ember_build.rb:103:in `system': Command failed with exit 1: pnpm (RuntimeError)
	from /var/www/discourse/script/assemble_ember_build.rb:103:in `<main>'
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:211:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:112:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/execution_wrapper.rb:91:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:70:in `conditional_executor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 1 Unicorn worker(s) that were stopped initially
You need to make a bigger swap file.
I had the same problem. This solved it
Can you explain how to? I’m not familiar with that. I remember someone talking about it, but I don’t think I’ve made any changes (well, apparently I probably didn’t and that’s what’s causing this).
Thank you
I recommend upgrading from the command line
cd /var/discourse
./launcher rebuild app
You might still have memory problems. If that fails, include the error and the output of
free -h
EDIT: Oops. Sorry, I didn’t read carefully enough:
Add swap is what to do. The way that I do it is
cd /var/discourse
grep swap discourse-setup
Then you can see the commands that discourse-setup uses to create the swap space.
Then you can do something like
./launcher stop app # if you don't you probably can't turn off swap
swapoff /swapfile # now you found the name of the file was /swapfile
fallocate -l -4GB /swapfile # adjusted from the one in the output
mkswap /swapfile # this "formats" the swap partiion
You can skip the other stuff about adding it to fstab and such, and just turn it back on:
swapon /swapfile
./launcher start app
Then you can check with
free -h
If you have no swap file, then you can run ./discourse-setup and it’ll add it for you and you can control-c when it starts asking you questions.
Use Google or youtube:
“Linux swap file”
Here’s Digital Oceans guide:
You usually need to add as much swap as you have RAM.
https://meta.discourse.org/search?context=topic&context_id=373634&q=Node.js%20heap_size_limit%20is%20less%20than%202048MB&skip_context=true
Updates
After a few conversations with Claude, here’s what’s happening:
I initially had this
sudo swapon --show
NAME      TYPE SIZE USED PRIO
/swapfile file   2G   1G   -2
That was still causing the error.
So I was able to increase it to 4GB, I believe:
sudo swapon --show
/swapfile file   4G 714.4M   -2
Now, here’s what’s strange: while I was doing this, I went back to the update page and to my surprise, everything was updated…
How is that possible, if it was showing me that error? :confused:
Anyway, I now at least understand that a swapfile is related to disk space, not RAM. I’m using DigitalOcean’s droplet 1GB RAM, 25GB disk.
So I guess having the 4GB swapfile is ok for now?
But still, why did it update, even after showing me that error?
A swapfile is a way to use some of your disk space as very, very slow RAM, so it’s related to both disk space and RAM.
25GB is just barely enough space. You’ll need to do a ./launcher cleanup before pretty much every command line upgrade.
What I meant was that, when I saw discussions about it, when people said “create a 2GB swapfile” I thought it was related to the amount of RAM, so in my case, I would not be able to do it, because I only have 1GB of RAM. Now, I understand that the swapfile, is in fact disk space, almost like creating a small partition. So, yes, they are related, because they “communicate” with each other when necessary, but I was being more literal with my comment.
That’s all I can afford at the moment and since I still have no real community, that’s enough. I will upgrade as the community grows.
So, you’re saying that before each update, even when using the admin panel to update, I should run ./launcher cleanup via Terminal?
No. Using the admin panel doesn’t make docker make more images it’s not using, but you may not have enough memory (ram plus swap) to do the upgrade from the admin panel.
This is all a bit confusing to me…
Some people said they were having the same issue as me, and creating the 2GB swapfile helped them. I now created the 4GB swapfile, but that was after I updated, so I will have to wait for another update to test it.
So, for example, if I upgrade to 2GB of RAM would that be good enough, even if the disk space is still 25GB?
I’m very new to all this, so I apologize if this is too obvious for most people. I’m just trying to figure things out as I work on it.
1GB machine with 4GB swap should be enough.
I would personally recommend at least 2GB with 2GB swap to start with but you meet the published minimum requirements of a standard install.
I would move on and use it and only upgrade if you find things are too slow.
You should have no problems with memory now.
Except, as you said, HDD will be full quite fast, and cleanup is must to do no matter how much there is RAM.
Thanks. For now I just want to start adding content and add some users until it makes sense to upgrade.
Off-topic, but still related to the disk space: when I was going through everything, I noticed that I was using around 18GB and when I asked ChatGPT, it said it was normal that Discourse takes that much space?
If so, then my 25GB server would be using 18GB for the installation + 4GB for the swapfile, leaving me with not a lot of space. Can you confirm this?
I’m not going to debate with your robot.
You are correct that the 4GB will come out of your available disk space (of course).
I just checked all folders and noticed that 12GB are being used by this folder:
/var/lib/docker/overlay2/
What is this and is it possible to reduce it by maybe removing files that are not necessary?
Perhaps see previous thread
Discourse upgrade fails due to insufficient disk space on 25G droplet
Perhaps also this thread
Maybe someone could say something like:
Without any extra context, that initial comment was not very helpful for me. I wasn’t expecting Discourse to use 18GB of disk space when other platforms like phpBB are way lighter (not being an expert, I have no clue why one platform is lighter than the other, but they are different, apparently). So when you said that 25GB is barely enough space without adding more context to it, while there’s nothing on the official installation page that says that Discourse will maybe that N gigs of space, I assumed that the default Digital Ocean 1GB RAM with 25GB was more than enough and maybe bigger communities would struggle with just 25GB. Since mine is just in the beginning, I didn’t see disk space as an issue.
Hope that makes sense.
